Old 05-09-2018, 12:47 PM   #3194 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Actually, do the run-pi-test2 first. That is a locked rotor test (but you don't have to lock the rotor). It doesn't require knowledge of the rotor flux angle, so you don't need the angle offset for it.
Once you get good convergence, then move to finding the angle offset. I would suggest on that one, do the following
angle-offset 0
// then give it a little throttle
angle-offset 16
angle-offset 32
and when it hits the zone where there is no movement from the throttle, add 128 to that, and that's the ideal angle offset. You can also subtract 128 instead, if you want the default rotation to go the other way.
then, type:
save
and hurray, you are done. drive into the sunset.
The LEM Hass 200-s is fine. It just means you will need to have
current-sensor-amps-per-volt 320
save
You can use any current you want from 0 to about 400 then, because 400 will be where the hardware overcurrent trip point is.
kits and boards
The Following 2 Users Say Thank You to MPaulHolmes For This Useful Post:
thingstodo (05-09-2018), wootwootman (05-09-2018)
