Old 05-09-2018, 02:04 PM   #118 (permalink)
towndrunk
Originally Posted by RustyLugNut View Post
. . . can you summarize the gains, if any, of your lean burn tuning?
Thanks,
I reviewed some old logs and it appears the gains are about 3 to 5 mpg at 60 to 65 mph, depending on rpm. In other words, about 8 mpg at 1400-1600 and about 3 mpg at 1800 rpm. At 2000 rpm, little to no improvement. I think we could get by with a little less cam/spark at 1400 rpm since that tuning was done at 10°F, but no-one has tested that theory.
I'm sure gains would be much higher with a vehicle that doesn't have such a high load on it.
2018 Chevy Volt
The Following User Says Thank You to towndrunk For This Useful Post:
RustyLugNut (05-09-2018)
