Old 05-10-2018, 07:00 PM   #830 (permalink)
Angel And The Wolf
You can buy larger diameter wheels to reduce the revolutions, or buy higher speed rated tires to pull at faster speeds. Finally, keep the tires aired up and the loads reasonable, and you should be able to pull at any reasonably safe speed.
Taller wheels and tires might do it, but in looking at utility trailers, I get info like this:
"This handy trailer meets or exceeds all road-ready specifications and DOT requirements and is ready to hit the road at up to 45 MPH."
https://www.northerntool.com/shop/to...2541_200612541
