Yes, it is intended as a converging duct. Area in vs area out determines the dimensions. I'd go with ~3/4" mainly so it doesn't clog up with snow or road debris.
There is a plastic piece there that is bolted to the fender somehow, maybe as a quick visual I yank it and see what can be done in that area. It is already at least 1/2" wide if not wider. I still think there is a problem with the exit angle and the wheel coverage.
