Old 05-19-2018, 08:23 PM   #372 (permalink)
Crashy
Originally Posted by bandit86 View Post
Battery inefficiency will be offset by electronics inefficiency at lower voltage
False. Every electronic device has a voltage regulator. At any voltage above the minimum, the regulator burns off the excess voltage as heat. So the higher the voltage, the less efficient
