Old 05-19-2018, 08:42 PM   #7 (permalink)
oil pan 4
I made a post about home CHAdeMO only with in the last few weeks. The single phase 240v 60Hz ones I found only charged at around 10 to 12kw.
If you get a flat in Australia you could die.
When I get a spare I will get a 5th full sized wheel assembly with no tpms.
Since mine has a 3 or 4 year old battery with most of its range intact I am not really thinking about a range extender beyond a flat tow setup.it appears that it should be able to do everything I was expecting it to.
The only range extender I might mess with is the solar panels, if the solar can take up most of the 200w 12v accessory that could give +2 miles per charge.
The trailer hitch is going to be used to pull my trailer and maybe even might trying pulling my chain harrow around with it. The leaf is definitely more comfortable than my tractor.
I'm probably just going to take a wheel off my trailer which i know has 5 on 4.5 zero off set and see if it fits the leaf, after I get the trailer hitch on. The back end of the leaf is up on ramps at the moment.
Then everything on my old "light weight wheels" post becomes relevant.
I was looking for OEM light weight wheels for my trailer that had 5 on 4.5 pattern. Most of the wheels found were 14 inch and up. I really only needed 12 or 13 inch wheels, any bigger and the trailer would be too high up off the ground for my liking.
I ended up going with alloy 12 inch load range E steel belted radial tires.
