Old 05-20-2018, 11:37 PM   #14 (permalink)
oil pan 4
The trailer hitch is on.
You reuse the tow loop 12mm bolts and secure the hitch with 3 nuts supplied by Curt on the rear passenger side. Instead of using the provided nuts I cut the nut plate off the old tow loop with my portable band saw and used it.
I figure the nut plate is stronger and there is no chance the nuts can back off.
Isaac Zackary (05-21-2018)
