Old 05-24-2018, 02:54 AM   #33 (permalink)
Isaac Zackary
Full sized hybrid.
Isaac Zackary's Avatar
Suzy - '13 Toyota Avalon Hybrid XLE
90 day: 37.18 mpg (US)
Another thought for Oil Pan 4. The 2012 Leaf has a water-coolant based heater. If you use the heater much one thing that can be done to improve heater efficiency is to wrap the exposed heater lines with insulation. Also the 2011 and 2012 Leafs were designed so that you can't turn on the climate control fan without engaging the heater or AC. But with the right knowhow, you can set up a switch that will allow you to use your fan but turn off the heater when you simply want air, like for defogging.
