I wanted to figure out a way to pull a trailer of batteries and/or small generator and charge our Leaf while out and about so we can do longer trips.
But, i would need to run high voltage lines from the front to the back...
Also, with the limited thermal management, would charging and discharging at the same time cause too much heat?
