lawn edging is worse than useless
when i see these threads discussing the use of lawn edging as air dams
i know the poster is "lacking in candor"
have tried and destroyed lawn edging air damns more than a few times
use a tire tread or two for wide applications , on the geo metro a 185 60 15 re 92 with both side walls sliced off to the edge of the steel belts is about
perfect
it will scrape sometimes but it will never break or crack or split or bend out of the way
unlike
the
useless
lawn edging
which will do all of the above in the first 30 days of use
