Old 05-25-2018, 07:44 AM   #1 (permalink)
blueberry
84 mpg! ninja 300
Hello everyone thanks for the add. Have a 2014 ninja 300 abs.
the mods:
+1 15 tooth front sporcket.
note due to speedo sprocket change it made a 6.7% lower reading than actual gps odometer. and was factored in and corected during calculations
Riding style: Stayed at or a little above speed limit on mixed 60%country road/30% city and %10 hwy. I full tucked when going over 40 mph and on hills to help miantian speed. Used kill switch at long lights. and costed on a couple big hills and into parking lots. Took advantage of the efi engine braking when slowing down as it cuts fuel off. kept rpm at 4k to 5.5 k rpms. also note im about 5ft9 140lbs
so i filled up reset and went 263 miles still had a quarter tank. went to the same pump and it took 3.12 gallons came out to 84.29 mpg! I feel i would have been better as the tires were under inflated 6psi the first half of the tank!
so heres the mpg i get for different rinding styles
hypermiling 80 to 90+ mpg
effcient riding 70 to 73 mpg
some spirited riding i was geting around 66 to 68 mpg
and harder rides an fooling around i was still getting 62 mpg!
In conclusion i thing the sprocket mod helps alot!
The Following 2 Users Say Thank You to blueberry For This Useful Post:
Grant-53 (08-13-2018), HHOTDI (08-12-2018)
