Old 05-28-2018, 09:56 AM   #3 (permalink)
oil pan 4
You need a big battery charger that can put out some real power. Not a battery tender or trickle charger that will only ever achieve a max voltage of 14v.
To do a real desulfur cycle and cell equalization you need to hold the battery to at least 15.5v for an hour or so. 16v would be better.
A 12 to 15 amp charger with "flooded" or "standard", a "gel battery" and "AGM" settings is what you will need.
