Old 05-29-2018, 11:52 AM   #46 (permalink)
RedDevil
90 day: 54.08 mpg (US)
Thread depth does not influence rolling distance.
In the contact patch the thread lies flat on the tarmac, so a worn tire has the same rolling distance as a new one.
I tested and found the rolling distance of a fairly worn tire to be about 3 cm less than the circumference as measured over the thread. With new tires the difference should even be greater.
