Old 05-29-2018, 07:46 PM   #3 (permalink)
ColoradoChris
Is it fuel injected?
The biggest thing working against my sportbike is the short gearing at highway speeds. If your revs are high on the highway, you might consider going down a tooth or so on the rear sprocket, at the sacrifice of a torquey low end.
It is fuel injected, but it uses what is basically half of a honda fit motor, so the redline is 6500 rpm, it turns about 3800 at 75 mph. Of course better fuel economy can be had at lower speeds.....
