http://www.emsd.gov.hk/filemanager/e...64/t5guide.pdf
Power factor is 0.95.
Power consumption of the ballast alone is 4-6w
You continue to waffle on about power factor when it has already been explained to you that domestic power meters measure watts, not VA.
You cherry pick the best ever fluorescent, inflate it's performance, then compare it to the worst ever leds and fudge their numbers to make them look worse. That is deceptive and misleading
