Old 08-29-2008, 12:46 PM   #187 (permalink)
jmilk
Originally Posted by ishiyakazuo View Post
But also worth noting is that the PIC that the ELM uses (PIC16F2x80) has hardware PWM and CAN as well, so CPU speed may be a non-issue
18F2480, right? Hardware CAN... that'll do it. And it's also my problem with ELM... they're re-selling a $5 chip for $30. That's a $25 license fee for what amounts to bit-shuffling software that shields a tad of the complexity of the underlying bus... and you're pretty much stuck with the firmware, because they don't provide upgrades.
The only reason I was talking about AT90CAN64 vs AT90CAN32 is because the 64 is less than a buck more, and is more widely available. (And let's face it, extra flash never hurt anyone... unless you're terribly obsessed with power consumption.) I'll also be picking up some ATMega328s.
There's no appreciable difference in power-consumption for flash memory based on capacity. IIRC, flash only actively powers the page currently read-from/written-to, so page count is immaterial. RAM's different, but too small to matter here. Clock speed and operating voltage are just about proportional to power-consumption, however -- even so, I don't think the maximum consumption of fully clocked AT90 (0.15W at 5V/16MHz) would matter in the grand scheme of things (the LCD uses 10x that); and an ATmega328P uses even less... theoretically, it's 0.05W at 5V/20MHz).
