Old 06-05-2018, 10:26 AM   #8 (permalink)
slowmover
90 day: 19.36 mpg (US)
Great numbers!
I tend to drive faster when in a van simply because it's not just my time that is being wasted. With a carload of people, I'm traveling at the fastest safe speed I can while trying to stay below the attention of patrolmen.
(I’m not going to pull punches, here)
Time being wasted?
1) What’s the percentage change in total braking distance from solo for the fully-loaded van?
2) And, from lower speed to higher? Each iteration. (What was the tire pressure change required?).
Consequently, what is the minimum highway spacing distance requirement in any of these?
You know none of this, do you? Consider your “skill” (ha!) somehow above reproach. Without this beginning, you don’t know “safe”.
Your premise of time-wasted is a giant self-deceit.
As was said long ago, “You know neither the hour nor the day”. (Understand this and the rest isn’t necessary).
And the same for all others who find auto travel a burden. To, get it over with as fast as possible. Who thereby make a mockery of shared responsibility with every demonstration.
You want it in Eco Modder terms? How many highway braking or deceleration events after entering, but before exiting?
“Travel speed” is the province of fools. Traffic volume dictates travel speed as surely as the sun rises in the East. The upper limit is constantly in modification according to it and other factors, equally-weighty. (Which should have been appreciation of tire slip angle and lateral acceleration; no van is capable of much while solo; but loaded?)
I’m all in favor of the use of cruise control. In which, how often did you cancel cruise control to get someone passing around you more quickly; that they could return to the travel lane 200’ or more ahead and thereby all avoid pack formation near your vehicle?
Was there ever a time you were surrounded by vehicles fore & art? To port & starboard?
Count yourself a terrible driver if this was avoidable in any sense whatsoever. The definition not only fits, it is statistically-valid.
The premise to travel is to arrive in the same shape as when departing. How that is achieved is the task. Driving for FE is a subset. It is finesse.
That finesses is the cruise control set speed most appropriate to elimination of braking events. and minimization of CC cancellation all while maintaining never less than 200’ of spacing (goal of 600’).
You, and others like you, have a long ways to go in becoming able to drive economically, as you haven’t first made a study of, much less mastered, “safe”.
I see your type daily. Never an understanding that what is overtaking in the mirrors counts for more than what is out ahead. A bright 12-year old can be taught the latter. But we’ve imported millions incapable of abstract reasoning, thus incapable of deducing the former. (Which is before visuo-spatial skill).
No one cares about your self-regard (self deceit) nor about the absence of negatives (citations, accidents, etc; same pride exists with those who’ve avoided arrest and prison sentence), but only about how well you are managing (making decisions about) what is happening around you, and how well that is being done.
Others far better than you are constantly having to take your selfishness into consideration of their own actions. But you believe (act the Fool) that your faster travel rate merits you (guffaw) special consideration.
Got news for you: The passing lane confers no ROW. None, except in the short moment of a pass. Never in overtaking. Also, one cannot block access to the passing lane (this list continues long and pitifully).
The day those better drivers don’t extend that allowance for your bad manners may be your last. Or, far worse, for one of those passengers. Perhaps that death is preferable to quadriplegia, as no long years of suffering ensue. Works better with Civil juries, that much is true.
Accidents aren’t accidental. Nor do they have single cause. So start by shoring up the timbers.
I’m appalled that EM is apparently, “engaging in the same unconscious bad behaviors, but for a lower out-of-pocket expense”. (The owner/moderator will be proud). But maybe not surprised at the fanboys around here of the electric car debacle unfolding at present whereby tech (Big Brother) is the only one accountable.
“Be a man” has become an exhortation without an echo.
The Following User Says Thank You to slowmover For This Useful Post:
TheRajunCajun (04-02-2023)
