Here is a silly question .. Many of you claim to change the filter more often than the oil. How do you do that? By removing the filter don't you drain some oil along with it? ABout a quart or so? If so and therefore, do you add an additional quart each time you change the filter?
I was wondering because I would rather change my filter more often than do a complete synthetic change and let the filter go for longer.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
