Old 06-13-2018, 01:45 PM   #2028 (permalink)
NeilBlanchard
Weather over time - is climate. We know the climate is changing - and therefore weather is changing. Systemic causation - by definition, the weather is changed, because the climate system has changed.
The so-called "permafrost" was named that for a reason. If you listen to the report I linked, it is staying warm TWO MONTHS longer than it used to. And they now have to use chilling tubes to keep the ground frozen. Someone has a business that only became necessary in the past couple of decades.
aerohead (06-13-2018)
