Old 06-15-2018, 12:04 PM   #19 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Here's a graphic showing the pressure measurements across the top of the hood relative to under:
Measurements were taken at 42 mph and averaged between one N run and one S run at each location; wind was 10 mph NW.
For vent location, the passenger side presents no difficulty; however, the driver side has the inverter at the front of the engine bay and the fuse box along the side behind the headlight, two things I would rather not get wet. A vent in the middle of each side right over that -1.3 reading would miss both of those, perhaps with an additional vent across the front just behind the radiator.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
California98Civic (06-15-2018)
