Old 06-15-2018, 05:23 PM   #48 (permalink)
ksa8907
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
I was told by multiple people that there is zero regen with brake pedal use. Is this not the case?
I was shocked to learn Tesla has zero regen with brake pedal use, which basically forces use of 1-pedal mode to recapture as much of that kinetic energy as possible when slowing.
Assuming the bolt is similar to the volt, braking in neutral provides no regen, must be in drive or low. If you are regen braking in drive and shift to neutral, the car will give a very apparent lurch as the mechanical brakes engage quickly to make up for the lost regen braking force.
