Old 06-20-2018, 02:57 PM   #11 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Not sure how that would work since starting requires several hundred amps. If I remember correctly, the BMS has a decent bit of phantom power draw too. If I'm undersizing the battery, I can't have large phantom loads.
You'd let the BMS control charging, and lighter discharging loads (like the rest of the car). You'd hook the starter wire direct to the battery's terminal. No worries about needing a big BMS, as long as it can handle the charging (and discharging, if used) amps.
Too many charging amps from the alternator for the BMS? Put in some diodes, so the battery can discharge as much as it wants, and a resistor to limit the charge current going to the BMS. Or a PWM current limiting circuit.
The Following User Says Thank You to Stubby79 For This Useful Post:
redpoint5 (06-20-2018)
