Old 06-21-2018, 07:27 AM   #14 (permalink)
Crashy
Do not use a bms. Use arduino with voltage dividers. Get a heavy duty latching relay which uses zero power unless triggered. Have the arduino turn on a signal relay which then feeds the latching relay if any cell is under 2.5v. If you want you can use more relays to discharge over x volts.
