Old 06-24-2018, 01:18 PM   #20 (permalink)
vskid3
vskid3's Avatar
Civic DX (sold) - '97 Honda Civic DX
90 day: 34.15 mpg (US)
GTO (sold) - '04 Pontiac GTO
90 day: 22.62 mpg (US)
Green Brick (sold) - '06 Ford Escape Hybrid
90 day: 31.93 mpg (US)
Originally Posted by elhigh View Post
I was wondering that myself. Prius drivetrain midships, battery pack under the seat. All the weight at the center of the car for fantastic handling. A stock Prius makes the 60 sprint in about 10 seconds but it also weighs over 3000 pounds. Create a 2000-lb MRe (Mister E!) and the modest power will nevertheless be sufficient to make an entertainingly quick car. You could use the entire front subframe and just bolt it to a new chassis like Pontiac did for the Fiero. Just lock up the steering gear (like AM General did with the Humvee) and it's good to go - or spend a modest amount of development dollars to eliminate the steering bits and save some unsprung weight.
Why not go all out and use a Camry Hybrid drivetrain? They'll do 0-60 in about 7 seconds and weigh about 3500lbs. MR2 would probably be 1000lbs less, so 0-60 would probably be in the 5 second range.
Or for maximum ridiculousness, 300HP AWD Highlander Hybrid drivetrain. ICE in the back, motor up front.
Camry Thread
E-Bike Thread
