Thread: Class 8 Trucks
Old 08-29-2008, 08:46 PM   #17 (permalink)
SmartTrucker
KickmeintheJimmy - '96 GMC Jimmy 4 Door 4WD
Originally Posted by IndyIan View Post
I guess aerodynamics is still a big issue with trucks, but how about the single wide tire vs, dual skinny tires? I don't know if the single tire has lower rolling resistance or not but it might be something to look into.
Also something simple would be coasting downhills in neutral, and pulse and glide should have good benefits for such heavy vehicles.
Can trucks maintain air pressure at idle in a long panic stop?
The super singles you are referring to have been tested and are a fuel & weight savings but unfortunately they don't have the same weight acceptances where we travel so we can't use them on our units at this point.
The sad thing is there's improvements that can be made but many are cut off from us due to the rate at which government moves on things
