Old 06-25-2018, 02:33 AM   #3 (permalink)
oil pan 4
What I might try is get it tested, if it passes by a lot it probably is the O2 sensor.
If not the code is correct and catalyst is below efficiency threshold, try to clean it.
Converters have been using a lot of palladium over the years, palladium is near a 15 year high, so you don't want to buy one if you can help it.
California98Civic (06-25-2018)
