Old 06-28-2018, 09:26 AM   #1 (permalink)
arcosine
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
sc1 up for sale $400 obo.
$500. Rust hole is welded up, drives, 40+ mpg winter. Im taking the new tires, check valve and hot air intake off. Going on craigslist this month. Being replaced by TDI Beetle....
...Yes, the one of a kind sc1 is now available for purchase. Its been average about 43 mpg in normal driving (70-80 mph), without hypermiling and without front skirts. 5-speed manual. My best tank was 63 mpg.
New subframe and lower control arms in Janurary 2018
New brake lines December 2017
recent pads and rotors
recent kml rear struts.
0-20 vavoline synthetic oil change with fram tough guard filter in march 2018
195/65R15 BF Goodrich tires 1 year old.
odometer: 168,000 miles
Has mods:
full coroplast belly pan, rear skirts, headlights moved flush, side mirror delete, modded bumpers front mini-skirts.
trailer hitch embedded inside rear bumper
Big anti-sway bars.
good clutch, changed at 100k
heat works, ac doesnt.
muffler is getting louder
has map sensor advance mod
passes emission tests
custom stiff sway bars front and rear
hot air intake with vacuum controlled flapper valve.
crankcase vacuum with one way regulating check valve
205F thermostat
kml rear struts in 2015
sometimes pops out of 3rd and 4th sometimes when cold cornering (has done this for the last 68,000 miles, since I replaced the transmission (beware of craigslist).
Has provisions for rotating direction finding antenna though roof.
Has port for fuel pump access.
See:http://ecomodder.com/forum/showthrea...ods-15529.html
Boat tail available free with purchase.
Only car tuff tested at the 2012 ecomodder meetup to have no flow separation front to rear, won the low speed coasting contest:
- Tony
