Old 08-29-2008, 09:45 PM   #37 (permalink)
whitevette
$ talks...
Originally Posted by sickpuppy318 View Post
I always notice an EXTREAM drop in FE when its oil change time. At 160,000 it uses practically none of the Mobile 1 Synth that i put in it. I can tell its time when the engine lacks power and FE. Now about 5-6k. Four and a half new quarts plus filter and the FE goes back to 36+. Right now getting about 31!!! I'm pretty sure any wear on the engine is happening now.
It seems you are changing every 5 or 6 K miles... and your Mobil 1 costs how much? Where is your gain? I'm not with you ... I use fleet oil (NAPA) for trucks 'cause it has zinc compounds in it (EP additive)... since EPA mandated all auto oils remove the zinc compounds...because that was damaging the converter element(s). Cheap, too....
