It really depends how big of a battery you attach to it.
Also how smart the battery management system is.
If for a 1kwh battery pack it calculates 100kwh input, then somethin MUST be wrong. The energy is going somewhere but where?? So it should shut downt.
This is like you drinking 100 gallons of water to quench your thirst and the pissing out 100 gallons of water. If it were to occur I am pretty sure you would go to a doctor. The bms will also stop functioning. Then again, it may not be so smart and be completely ok with it.
