Old 07-11-2018, 09:27 PM   #1 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Keeping cool without A/C - heater core bypass
Most cars seem to have heater cores that constantly circulate coolant -whether cabin heat is on or off.
All that separates that heat from the HVAC system is a thin plastic blend door - and the heater box itself must bleed a fair amount of heat into the cabin. Certainly after an hour or more of driving, this must be adding to in cabin heat soak.
So why not fit a valve to the top hose of the heater? Doesn't have to be anything fancy - a manually operated valve that you turn twice a year would be fine. As a temporary test you could just use some wood blocks and a G clamp.
It would also be a great mod for those of us with ACC, as I'm forever trying to guess the temperature at which it will neither use A/C nor bring in unwanted heat.
I've just disconnected my Proton's heater core which got me thinking about this - unfortunately that means I can't run a test to see how much heat gets through a heater core that's 'off'.
