Old 07-12-2018, 12:03 AM   #5 (permalink)
Effic1ent1
Effic1ent1's Avatar
MZ3 - '13 Mazda 3 i Sport
90 day: 49.47 mpg (US)
Originally Posted by Natalya View Post
We don't need pan or tilt functions.
POE stands for power over ethernet? It might be easier to just run a bunch of ethernet lines than to do outlets plus wireless. None of the locations for the cameras already have outlets available.
We would probably do motion detection-on only. We may only need a couple weeks worth of video, not a whole month. I guess I need to look at compatibility of solid-state drives.
Thanks for the advice guys.
PoE=Power over ethernet and is the way to go. Get some RJ45 crimp connectors, CAT 5e or CAT 6 cable and a crimper and build your own cables. Just to be clear the motion detection only is just a setting/feature in the software that can be turned on/off for each camera. SSD's will certainly work, but are not typical for cctv setups. HDD's are normally used and a 2tb on amazon is only $60. 2x2tb hard drives in a RAID 1 configuration for $120 bucks would likely be all that you need for 4 cameras in motion only for 2+weeks of data.
The Following User Says Thank You to Effic1ent1 For This Useful Post:
Xist (07-14-2018)
