Thread: sc1 aero mods
Old 07-13-2018, 01:20 PM   #181 (permalink)
jjackstone
If you get to the point where you are going crazy and can't find the answer check the transmission(drive shaft?) speed sensor(assuming that vehicle has one). My ex had that as a problem on a Toyota with similar symptoms once. Four mechanics couldn't figure it out. I found the solution online in about ten minutes.
JJ
The Following User Says Thank You to jjackstone For This Useful Post:
aerohead (07-14-2018)
