Old 07-14-2018, 11:32 AM   #35 (permalink)
19bonestock88
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
I fixed my gear/chain skipping... I adjusted the limit screws on the rear derailleur to where both 1st and 7th gears line up correctly when selected, and I noticed my rear wheel not 100% straight so I fixed that too...
I’m considering bumping tire pressure to 80psi instead of just 60, but the issue is that my rear tire has a max of 50 listed on the sidewall, and the front tire just says to inflate to 86psi... so technically my front is under inflated and my rear is over... I really need to get a pair of matching tires and matching tubes... rear tire has presta valve and front has a schrader valve
My current Ecotec project...
My last Ecotec project...
