Old 07-15-2018, 11:38 PM   #9 (permalink)
fusion210
Winsight - '06 Honda Insight
Gen-1 Insights
90 day: 72.19 mpg (US)
G1 Insight is the king. Although I think the deals are going to dry up, you can still find them for under $1500 in great shape with a dead battery. You can build a grid charger for under $50 and try to revive it or just bypass it. I heard the CVT ones do really well with a bypass but after mine went out with a manual trans it was really crappy taking off from a start. If it was level ground that's fine. A little slow, never got a horn honk. But if you find yourself on an off ramp at a stop with a steep grade it's brutal. Clutch out, 50% part or full throttle, someone could do a little jog and go right by you on foot.
The Following User Says Thank You to fusion210 For This Useful Post:
Ecky (07-25-2018)
