Old 07-20-2018, 05:15 PM   #1 (permalink)
zretrareo27
2004 Honda Civic Non Hybrid CVT - Help with Tires!
I've been getting about 48mpg when I drive carefully. When I bought the car it had Sumitomo Touring LST tires on it. They're starting to wear out and will need replaced asap.
Manufacturer recommended tire size is: P185/70R14 87S at 30psi cold (35 warm).
I tried to posts links, but I'm a new member and it's not allowing it.
I want the highest mpg tires available while sticking as close to manufacturer specs as possible and keeping the odometer/speedometer accurate.
I've looked at the following:
Replacing with the Same ($58/ea) - 17lbs
Michelen Defender T+H ($104/ea) - 17lbs
Michelen Defender (Discontinued $100/ea) - 19lbs
Hankook Optimo H724 ($59/ea) - 15lbs
Which of these looks best from the MPG standpoint, as well as being gentle on my CVT, and what is going to give me the best value? I don't want a tire that's going to pop randomly, so quality may be important. I cannot find any LRR rated tires in the P185/70R14 class.
Any and all suggestions are greatly appreciated!
