Old 07-21-2018, 10:47 PM   #37 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Originally Posted by stefanv View Post
As my hyperkilometring evolves, I've found I use my kill switch more and more. When using it while rolling, I've usually restarted by letting out the clutch, but it's very hard to do this smoothly, since of course I can't match engine RPM to gearbox RPM when the engine isn't running yet. I think if you do this smoothly, it's hard on the clutch, and if you do it roughly, it's hard on the engine, transmission, and mounts. Thus, I've changed to restarting using the key.
Correctly bump starting shouldn't be hard on the clutch. It takes 1/10th of a second to spool up around 40kg of mass inside a small engine. It takes about a second of slip to get a 1000kg car moving from a stand still. The wear rates aren't even remotely comparable.
