Originally Posted by oldtamiyaphile
Correctly bump starting shouldn't be hard on the clutch. It takes 1/10th of a second to spool up around 40kg of mass inside a small engine. It takes about a second of slip to get a 1000kg car moving from a stand still. The wear rates aren't even remotely comparable.
The difference is in the speed delta. To get the car moving, you're starting with an 800 or so RPM/difference (engine speed 800 RPM, driveline speed 0). To restart the engine at speed, the difference is around 2000 RPM (engine speed 0, driveline speed 2000). So that 1/10th of a second is probably about equivalent to 1/2 a second of getting a car moving.
