Old 07-25-2018, 01:28 AM   #35 (permalink)
me and my metro
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
When I lowered my last Metro I removed the bump stops all together. I only hit the limit once and it was with the car loaded and in my driveway. I recommend leaving a little bump stop. I lowered the rear of my Saturn L 200 sedan by cutting one coil off the spring. I cut the bump stop in half, the rear came down about an inch and a half. The ride is fine I just need to run it through the alignment shop the rear toe was off before and this made it worse. There is a lot of adjustment in this car, I may need the adjustable lower arms to get the camber correct.
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
