Old 08-01-2018, 03:53 PM   #55 (permalink)
jamesqf
Originally Posted by Angel And The Wolf View Post
It would be better to just add the solar created electricity to the grid.
The problem is that you can't just arbitrarily add energy to the grid, there has to be something out there to immediately* use the energy you put in. Try to put in too much or too little, and you risk destabilizing the grid and causing a blackout.
Most of the generation on the grid is can be throttled, at least within a range. You can let more or less water out of your dam, burn more or less fuel in your fossil fuel plant, &c. But there are limits on these. You may be required to maintain river flow within certain ranges; if you run your FF plant outside its most efficient range, you're wasting fuel, and so on.
But solar & wind aren't really throttable. You use what it produces, or it is wasted. The throttable generation on the grid can compensate for some of this, but only a limited amount. So if you have excess solar or wind power being generated, storing it - even relatively inefficiently - is better than just throwing it away.
*OK, technically that's not quite true, but it's a really good approximation. Adding energy will slightly increase the voltage & frequency, just as trying to draw more than is going in lowers voltage & frequency, causing "brownouts".
