Can you tell me more about your resistor replacement.
Are you still using the standard controls or your own control buttons.
If the standard buttons how do the resistors work?
Each fan level is connected to the fan through a different value resistor? Or is there some logic where different resistors are switched on in parallel to get the desired voltage drop to the fan?
My blower just stopped working and i suspect it is the resistors. Might aswell replace it with something more efficient. Arduino based.
