Will test the blower with 12v directly.
I did check the fuse and it appears ok. It did happen at a bumpy road so i am hoping something got lodged in the fan or the harness popped out.
Back on toppic,
Redpoint5,
I have a bank of 6 capacitors 500F each. Do you think they would be enough to start a 2L car? I will be using a boost converter to feed it to implement Luno’s implementation.
Capacitors instead of lead battery. Capacitor charged by lithium batteries. So alt is virtually disabled.
