Old 08-07-2018, 04:07 PM   #2 (permalink)
oil pan 4
Let me know how it works.
I spent about $600 on cells for my 60ah 13v LiFePO4 batt. A BMS wouldn't be a bad idea.
It won't work unless you external charge it. You need at least 14.8v a vehicle alt will typically make 13.8 to 14.4v most make around 14 to 14.2v I have found.
I say external charge it.
I would hook the battery straight up to the vehicle charging system like normal, since you are only supposed to run 10 amps through the charger circuit. An lithium battery will take full alternator output, which will be a lot more than 10 amps, bad for the charger circuitry.
