Old 08-10-2018, 02:49 PM   #104 (permalink)
mpg_numbers_guy
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
Originally Posted by 19bonestock88 View Post
I think I ran over a nail or maybe one of the big staples we use at work, though it didn’t stay in the tire...
Dunno about the HX wheels, not sure if they would fit on my Saturn, and I’d lose lots of rolling diameter... I’m currently upsized to a 205/65-15 tire(5.3% taller than stock)
I downsized from 15" to 14" rims and they fit fine. Unless your brake calipers are unusually large they should fit, and even if not you could always get some cheap 1/4" spacers. Is 205 width the stock width? Seems wide for a car not that much larger than a civic.
195/75R14 tires are about 0.02" taller than your current setup and I found some online for $28 each, cheap tires you could air up to 60 psi or higher and get some good FE out of. 185/80R14s are even taller and narrower but just over $200 for a set. HX rims are fairly cheap and you could probably sell your current setup and cover most of the costs.
Narrower tires also make wheel skirts easier to implement.
Just a thought...maybe.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
