Old 08-12-2018, 08:02 PM   #37 (permalink)
ksa8907
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
I've experienced a vacuum leak on a MAF hose before, and it was similar, but not as bad as these symptoms.
I'm up to 8 cold starts with no probs since putting the Metro's coil back in.
However the car did throw a p0400 code on a 200 km trip this weekend. Intermittent EGR valve problem (I've seen it once before). I wonder how a stuck-open EGR valve would make it run.
I need to take it off & clean the valve &passages.
Bad, very bad. Had an egr that was slow to close, would die everytime it came to a stop. Finally figured it out when I logged engine parameters on a drive. IAT shot to over 250° in mere seconds, only thing that gets that hot is.... exhaust.
The Following User Says Thank You to ksa8907 For This Useful Post:
MetroMPG (08-15-2018)
