Would this EV setup work?
I've recently acquired an unfinished kit car project that i'm hoping to complete using EV components.
The car is RWD and i was hoping to either just use direct drive or get a gear reducer of some sort. I'm looking for a pretty decent power output.
I was thinking of using the following components but i want to check with some people that have more knowledge to see if this system would actually work.
Motor - Netgain Warp 11HV or Kostov K13 Direct Drive
Controller - Soliton 1
Batteries - 72x Sinopoly 200AH LiFePO4 3C in series - 230.4Vx200AH=46Kwh
Charger - Eltek 67.120.0 150-260V 10 Amp
BMS - Orion 72 Cell 1000A
Car should way about 1200kg and is somewhat aerodynamic, I'm hoping to get plus 100mph and a 0-60 time of less than 6 seconds with a range above 130 miles.
Am i correct in thinking that because the batteries are 3C and 200AH they will produce 600A which multiplies with the voltage to give power output? 600A*230.4V = 138.24KW
Thanks
