If the cellulose does not rebond across fibers crushed and pushed together it would not get stronger than the original wood in its original thickness, rather weaker as the pressure will do some damage.
So as they claim it is remarkably strong, it must be rebonding. Then it would rebond also if paper was used, and the original direction of the fibers ceases to be important. It becomes one massive block of cellulose.
I still like the idea of using paper as it would facilitate creating complex shapes with controlled thickness. Any excess paper would be sheared off and recycled.
