Old 08-15-2018, 04:49 PM   #2440 (permalink)
aerohead
electric fields
Electric universe explains why we see things that that we thought were caused by dark matter, dark matter no one has been able to detect and why a lot of things look like they have been influenced by electric fields but no one thought electric fields could be that big.
Are you acquainted with inverse-square and inverse-cube laws with respect to electric or magnetic field strength?
Have you noticed how tight the air-gap is between the stator and rotor of an electric motor, generator,or alternator?
Even Earth's enormous dynamo/magnetic field induces nearly zero voltage in a conductor laid across the ocean floor.
If powerful 'cosmic' electric/magnetic fields penetrated Earth's magnetosphere,it would have been reflected as an induced-current/DC voltage in the trans-Atlantic cables measured by research Geo-physicists.
