Old 08-17-2018, 06:55 AM   #2 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Yes are we talking the 03 in sig.
It is do able find a picture, cfd or video of smoke over the aera for your make and moddle would help make an educated guess on deparcher angle. There is an F-150 with theas oem up for studdy. The duct you speek of is called a diverging converging duct. Behind your opening you would flow the 7° -15° max ,however, vortex generators strategically-placed on the insides of Curves would allow you to exceed that 7 - 15° by slightly increasing the size of the turbulent boundary layer but still maintaining a laminar attached flow. Studd there use in FAA approved use to fix plains with bad manners in a stall. 15°off the direction of air move ment. You will have to account for the lost cross sectional flow aera on the easy high pressure out side. A dirt road @35mph following safe distance, but in the dust trail with some video would give you a wind tunnel in free air so to speek.
The central high presher zone would give you the highest pressure differences = highest flow. That is why Aerohead used that aera for his cooling entry.
You could do something like this . Short ducts from the fog light buckets or go from the center.
https://www.bodykits.com/i-24306591-...ip-490187.html
hope the reading and ideas help the time go by with a bum leg. Best of luck with the recovery
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
