Old 08-20-2018, 01:08 PM   #4 (permalink)
teoman
teoman's Avatar
A3 - '12 Audi A3
Also, you are increasing surface area of the gasoline. If your tank is not fully sealed, then you will lose a bit more fuel to evaporation.
If your objective is to make the tank smaller, you could add a collar to the tank side of the gasoline inlet. That way air replaces gasoline.
