Originally Posted by gumby79
Slide mechanism... bucket seat slide rails
snip
You sir are a genius. If I can find a set from an old VW bug, those were designed to allow the seat to be removed just by sliding it off, thus making the box removable as well......
The intent, is to have a backrest mounted on the box that can serve the driver in the forward position and the passenger in the rear position as well as allowing access to the fuel cap....
